× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80 Disconnecting Hardwired connection only
On FW 1.0.1.58
Just randomly a few times a day anything hardwired to the rax80 will disconnected and then immediately reconnect. Everything connected via wifi stays connected without any interruption. Been extremely disappointed with the RAX80 and just went past my return date. I would gladly taken this one back and gotten my money back. Should of never switched from my x10.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 3
SAM_the_GAM
Luminary
Re: RAX80 Disconnecting Hardwired connection only
The problem you are describing is currently a bug in 1.0.1.58 firmware. Downgrade to 1.0.1.56 or 1.0.1.40 and the problem goes away. I encountered the same disconnection issue with 1.0.1.58.
Message 2 of 3
I've downgraded to 1.0.1.40 hopefully no other issues will come up
Message 3 of 3
Discussion stats
  • 2 replies
  • 1766 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
