× Our systems will undergo a planned maintenance on Sunday, May 19, 2024, between 12:00 AM and 02:00 AM Pacific Time. During the maintenance window, you will not be able to log in to your MyNETGEAR account (including apps), renew a subscription, or register a product. However, you will still be able to use guest checkout to purchase a new product or subscription service. Updates will be posted to Status.NETGEAR.com. We apologize for any inconvenience this may cause.
Orbi WiFi 7 RBE973
Reply
RAX80 Netgear NTP Not Syncing/Clock not Advancing
onurich01
Tutor
My RAX80 Clock was last sync'd 05AUG 11:07. It will not re-sync, and the clock has not advanced since. My log continues to fill with the same time log for each event. The seconds increment but the minute does not ever roll over.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 5
Nmouneimne
Apprentice
Re: RAX80 Netgear NTP Not Syncing/Clock not Advancing
I had an issue with my RAX80 not syncing the time on the latest firmware  (1.0.3.98). I had to downgrade to 1.0.3.88.
Message 2 of 5
Pokemon888
Guide
I have just got this RAX 80..3 days ago.  Circle unable to track time usage on devices. I have logged the call to support.
I have done the factory reset and wire uploaded new firmware ( V1.0.3.98_1.0.46 ) to the RAX80 router. Still the same. Clock not advancing and changing time zone to Melbourne failed to save after applied.
At this stage I am using V1.0.3.88_1.0.41 previous version. The clock is in sync and setting the new time zone- Melbourne also saved and Circle is working.
Hope they correct the firmware.
Message 3 of 5
Pokemon888
Guide
New update :
Netgear Engineer is getting new firmware done.
Message 4 of 5
SAM_the_GAM
Luminary
I sent a private message to @Christian_R  with my serial number & email address. I was sent the beta firmware which has solved the NTP Router Time Issue and ipV6 connectivity.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1372 views
  • 3 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
