× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80 device type pick list is blank
pjmulvaney
RAX 80 Firmware 1.0.1.70_1.0.30
In summary I have close to 30 devices connected, and I want to begin my QoS setup to prioritize some traffic such as my XBOX which tends to lag and disconnect.
Question/Problem:
Under Basic/Attached Devices and I select a device and there is a drop down for "Device Type" that is blank, and the drop down doesnt list anything.  What is that field used for and why is it blank?
Thanks in advance.
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 6
Christian_R
NETGEAR Employee Retired
Re: RAX80 device type pick list is blank
Hi pjmulvaney,
If you don't mind, would you provide a screenshot of what you see.
Thanks,
Christian
Message 2 of 6
JeffMills
I have the same issue.  Nothing shows up in the Device Type drop down.
Attached is a screen shot that doesn't show much because there isn't much to show.
I have clicked on the Device Type dropdown and that is what it looks like.
Message 3 of 6
Christian_R
Hi JeffMills,
May you let us know what firmware version your router is on.
Thanks,
Christian
Message 4 of 6
JeffMills
Firmware version V1.0.1.70_1.0.30
Message 5 of 6
pjmulvaney
What is that drop down field used for specifically. I read some other posts saying that java is required to display the fields but that didn’t work for me either.
Message 6 of 6
Discussion stats
  • 5 replies
  • 930 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
