× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAX80 shows under my network sharing devices
x-emblem
Follower
Hi, I saw the network device 'RAX80' under 'Shares' on my Mac. I suspect that it is the ReadyDLNA Media server, but even after turning that off, it doesn't go away. I don't have any sharing on my network apart from my NAS and my previous D7000 doesn't shown anything like that. Any ideas what it could be?
Model: RAX80|Nighthawk AX8 8-Stream WiFi Router
Message 1 of 2
schumaku
Guru
Re: RAX80 shows under my network sharing devices
Probably a host announcement up for ReadyShare (Nighthawk AX8 User Manual, Ch 8, p.113 ff) which is up regardless if a USB storage device is plugged or not. If you have a spare USB HDD or Flash drive (with one of the required file systems) you can plug it to the RAX80 USB port and check....
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1399 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
