- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
RAXE500 an Intel AX201 Latop
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just purchased a RAXE500 router. I am using a Asus Laptop with a AX201 Card in it. My can see my 2.4 and 5 networks but not the wifi 6 netowrk. My Phone see it no problem but my laptop cannot. Any ideas how to fix that?
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Intel's AX201 doesn't support the 6ghz band.
The AX210 does.
Wifi 6 is different from wifi 6E.
Wifi 6= 2.4ghz and 5ghz
Wifi 6E= 2.4ghz, 5ghz, 6ghz
6E includes the 6ghz band. So if you're device doesn't have the capability for 6ghz built in (as the AX201 doesn't), then you won't be able to see/use it.
The good thing is, many laptop's have the capability of upgrading the wireless card. I've done it a few times. Might check out your laptop and how hard it'd be to change out.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
回复: RAXE500 an Intel AX201 Latop
Can you go into a little more detail with this?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The AX210 does.
