- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- 1
- 2
- Next »
RAXE500 power adapter replacement................
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: RAXE500 power adapter replacement................
Checking with my CAX80, RAXE500 and RAX120v2 and a RAX50v2, the CAX80 and RAXE500 both have the larger plug 7.4mm / 5mm without center pin inside. The RAX50v2 and RAX120v2 both have the smaller plug with the center contact pin in the middle. I can only presume that at least the RAX120 and lower model series are all the smaller plug. I don't have the RAX200 so not sure about that model. I presume anything RAXE will have the larger plug that doesn't have the center pin for these model routers.
It's not an oversight when it comes to the center pin missing, more like power design and flow needed by these devices that may require more current and also regulatory considerations would be a factor as well.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep. Nobody talks about the un-common plugs like these larger ones which is why one reason this thread was started. These are not common plugs and only seen on these particular devices and newer 9 series Orbi systems.
Seems like these larger routers that have more features and do more seem to required more power specs so maybe one reason why NG went with this particular plug design.
- Mark as New
- Bookmark
- Subscribe
- Permalink
AC adapter for Netgear Orbi 960 970 RBKE96 , RAXE500 / RAX200 wifi-7 router, here is the best one I found.
https://www.amazon.com/dp/B00IFWXZDE
19V ac adapter
- Mark as New
- Bookmark
- Subscribe
- Permalink
the one in Amazon is a standard HP 19V power supply, in photo which you can see there is a pin inside the plug center..... have to confirm with seller b4 place order
- « Previous
- 1
- 2
- Next »
