× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
RAXE500 wont allow Nest camera to connect
sbatchik
Tutor
Have a brand new RAXE500 router and set up everything but 1 of the 4 NEST Cameras will not connect. I get error code C224. It will connect to my hotspot but not the network or guest network. I have worked with Google and Netgear and no one seems to know what to do.
It does find the network during setup, but times out and says error code C224. This is the NEST INDOOR Cam.
 It appears other people have had same issue but I can not find a solution.
I also bought a brand new Nest Indoor Cam and tried to set it up but got the same error code C224.
Any help would be much appreciated!
Message 1 of 13
Accepted Solutions
sbatchik
Tutor
Re: RAXE500 wont allow Nest camera to connect
Actually ot in touch with Netgear again . This time after an hour of testing, they flashed the new beta firmware and everything works great!
Message 11 of 13
All Replies
Guru
Is Smart Connect enabled? If it is, try disabling it...
Is the camera being connected near or in same room as the router?
Message 2 of 13
Guru
Also what security mode on the wifi radio are you using? Mixed WPA2 and WPA3? Try WPA2 AES only.
Message 3 of 13
sbatchik
Tutor
Smart connect is disabled. I did move the camera next to the router but still same error code. Google and netgear have been no help other than unplug and restart.
Message 4 of 13
sbatchik
Tutor
Using WPA2. It connects right away using the old Linksys routing but the speeds were slow compared to the Netgear. I dont want to go back but need to figure out how to get this camera connected.
Thanks!
Message 5 of 13
Guru
Try this, disable wifi security on the router. Set for NONE. See if the camera connects if so, I presume there maybe a wifi security mode issue between the router and camera.
Re-enable WPA2 and AES after checking this.
Message 6 of 13
sbatchik
Tutor
Thanks for the suggestion, unfortunately it did not work. I get the same error code C224. I worked with Google for over an hour this morning and was escalted to tier 2 support who just said "Its not the camera its your router." and sent me instructions for wifi settings on router. That was a ton of help.
Message 7 of 13
Guru
Ok well, if it won't connecte even while the router is OPEN, possible wifi connect issue between the router and this camera. Is this the only camera you have? Any others connect if you have others?
I recommend you contact NG support and let them know what your seeing. Reference this thread.
https://my.netgear.com/support/contact.aspx
Message 8 of 13
sbatchik
Tutor
Thanks! I will do that! Yes the Nest Door bell, Nest Indoor IQ, Outdoor IQ and Battery Nest all connected. The issue one is the Nest Cam indoor model #A000005 which is the orginal nest cam. I also thought it may be this camera specific but seems odd that you have a top of the line router and it wont communicate with the nest.
Appreciate your suggestions!
Message 9 of 13
tonydi
Luminary
What's the actual firmware version number on the RAXE500?
Message 10 of 13
sbatchik
Tutor
Message 11 of 13
Guru
Good to hear. Glad NG helped out.
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
Message 12 of 13
tonydi
Luminary
Perfect!  I asked because I had massive issues with my Nest cameras and working with some great people at Netgear (Nest absolutely refused to even talk to Netgear engineers) we got some special tweaks to fix the problem.  If you weren't on one of those FW releases I was going to suggest someone to contact.
Message 13 of 13
Discussion stats
  • 12 replies
  • 3573 views
  • 4 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
