- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Rax40 Wi-Fi signal suddenly missing after update latest firmware 1.0.4.102
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Rax40 Wi-Fi signal suddenly missing after update latest firmware 1.0.4.102
There's a wifi on/off button on the router. Maybe it got it?
Push and hold it for 2 seconds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
What box is still empty?
clicked it? You mean the wifi on/off hardware button on the router? did you hold it for 2 seconds?
If you do a wireless scan (not with the built in wireless) does it show?
Do all devices have issues/
Did you factory reset the router? (push and hold reset for 7-15 seconds while powered on)
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try a factory reset next time FW is updated if you run into problems after doing a FW update.
@pachan888 wrote:
The router hardware button is on, I think it is radio on. But I cannot search the Wi-Fi signal (maybe radio off). I connect lane cable to router to check the software config and get below result. Finally, I fall back to old firmware version v1.0.3.94_1.0.1. Everything become normal and set make the setting as usual.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As an FYI, I have a RAX35 which is the same as the RAX40 without the USB port.
I updated to FW 1.0.4.102 and have had no problems with my wifi. I did not need to do a factory reset after the update either. Your problem may have been a fluke. I suggest you make a backup of your router settings and try installing the update again.
