× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Should I use 2.4 or 5GHz in WIFI 6?
aCiDeViL
Should I use 2.4 or 5GHz in WIFI 6 for streaming?
In WIFI 5 I need to use 5Ghz to have a more reable connection on my lives streams but in WIFI 6 I am not sure if this matters, can anyone help me?
Message 1 of 2
schumaku
Guru
Re: Should I use 2.4 or 5GHz in WIFI 6?
5 GHz is always the better choice as it can supply a much higher bandwidth over the 2.4 GHz band. However, a good 2.4 GHz coverage can be sufficient. Not much of a difference to WiFi 5 by the way.
Message 2 of 2
Discussion stats
  • 1 reply
  • 481 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
