× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Trying to setup Kasa smart plugs and my nighthawk modem kicks off all wifi to my house(told try here
Scoves
I have the nighthawk model RAX35.   I just obtained some Kasa Smart WIFI Plug Lite HS103's.  When I try to set them up to my internet so they can be used my wifi goes down.  The Modem disconnects all wifi and will not turn it back on.  I have to unplug the Kasa Smart plug to get it to start my wifi back up.  Something is going on between the modem and the Kasa smart plugs.  I tried working with Kasa but they said it is not on their end.  That it is on the Netgears modem end.   Which stinks for me becuase I am a few months out of warranty to get support.  Which makes it almost cheaper to go out and by a whole new modem instead perhaps not a netgear one at that.   I am wondering before I do all that if anyone has had similar issues and had them resolved?  Or would know why this occurs.  I have set up another brand of smart plug and it works fine along with other wifi items I use but for some reason the kasa ones disagree with my modem.  Thank you for any help.
Firmware version by the way for my modem is v1.0.3.62_1.0.1
Message 1 of 3
Accepted Solutions
Scoves
Re: Trying to setup Kasa smart plugs and my nighthawk modem kicks off all wifi to my house(told try
I solved the issue finally.  I was able to update my firmware and it fixed the issue.
Message 2 of 3
All Replies
Scoves
Message 2 of 3
Christian_R
NETGEAR Employee Retired
Hello Scoves,
Thanks for providing an update to your post as it may possibly help others in the future.
Christian
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 949 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
