× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Turning off armor
SForsgren
Follower
Turning off armor
I am getting a url blocked and I unblock it in the app but still doesn’t work.
If I need to get to a site that Netgear is blocking, can I turn off the feature that is blocking it?
Seems odd that unblocking in the app still doesn’t seem to work.
Thanks for any insights.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 2
slackrl
Luminary
Re: Turning off armor
Hello SForsgren
You might try
1. Rebooting the router.
2. While the router is down reboot the device the app is on.
3. If that does not work try turn the feature off at the router with a web browser.
    by logging in to the router, use routerlogin.com or routerlogin.net.
slackrl
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 694 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
