× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wake on Lan with (RAXE500)
MrPoWeR
Follower
How do I enable wake on lan on my nighthawk AXE11000 WiFi Router (RAXE500) router?
Model: AXE1100 |Nighthawk AXE11000 (RAXE500)
Message 1 of 3
Guru
Re: Wake on Lan with (RAXE500)
Maybe a better description of what you're trying to do would help.
the router itself shouldn't be going to sleep or need the wake on lan function.
Message 2 of 3
Guru
It's possible that the user maybe referencing Wake-On Lan feature on a PC or device. Something that users may be able to enable on a supporting PC or device. Some routers had a Wake-On Lan port forwarding features back in the old days. Not sure of the RAXE or if any newer gen NG routers support this feature anymore. Wake-On Lan is a PC or device supported operation. I would check into the PC mfr or devices help and support information on if these products support WoL and how to enable it there.
Message 3 of 3
Discussion stats
  • 2 replies
  • 857 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
