× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
Wifi booster
Dap-68
Wifi booster
I'm looking to boost my wifi signal at my house. To my shop. Which is 100' away. Is this possible?
Message 1 of 8
Dap-68
Re: Wifi booster
I'm not sure what product I need. That's why I'm asking this question
Message 2 of 8
Kitsap
Master
Re: Wifi booster
Basic answer to your question is yes, but.
Does your shop have power in it that originates from a subpanel to the house?
If yes, you might consider a power line extender.  As an example only from Amazon, https://a.co/d/1HRePwu.
Message 3 of 8
Re: Wifi booster
This would be a good place to start:
WiFi Boosters & Extenders | Wifi Range Extenders | NETGEAR
It will give you some leads.
Message 4 of 8
Re: Wifi booster
@Dap-68 wrote:
Which is 100' away.
That's a hell of a stretch.
Message 5 of 8
microchip8
Master
Re: Wifi booster
WiFi signals can go only so far. WiFi has a finite reach due to physics, which you can't beat at its own game. There is no magic you can use to extend the signal. 100' is a "long" distance and even if you get some signal, it'll be pretty weak.
Message 6 of 8
Guru
Re: Wifi booster
Message 7 of 8
Guru
Re: Wifi booster
Would a wifi range extender make the distance? Maybe
but you could do it right and either run an ethernet wire or use something like a point to point system.
Netgear has Airbidge but its been going in/out of stock (more out of stock) lately.
so it might be worth looking on amazon for other point to point systems that you could use.
Message 8 of 8
Discussion stats
  • 7 replies
  • 759 views
  • 1 kudo
  • 6 in conversation
Announcements
Orbi WiFi 7
