× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
is Netgear nighthawk ax8 8 stream ax6600 vpn capable?
Goldheart
Just purchased the nighthawk ax8 wifi 6 6600 router... was told by best buy that I could install my express vpn on it... but when contacted express vpn they said that this particular netgear router is not VPN capable... Anyone know any more about how to set up a vpn on this router?
THanks
Message 1 of 4
Guru
Re: is Netgear nighthawk ax8 8 stream ax6600 vpn capable?
There isn't.
ExpressVPN is 3rd party firmware that installs to a router. And expressvpn only supports a few routers. I haven't seen a single AX router from netgear supported on it.
Plus its 3rd party firmware and you wouldn't see anything about it on the official forums.
Message 2 of 4
Goldheart
Thanks for the reply... That's what I thought...
Is there a vpn that can be set up on my nighthawk ax8?
Message 3 of 4
Guru
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1403 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
