- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
netgear nighthawk wifi 6 router rax120
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello, Friends:
I just brought this unit and upgraded to the latest firmware. I'm trying to setup an PBX phone system I can't seems to do port forwarding to open HTTPS URL. Could someone please help?
It say 403 - Forbidden
I opened and forwarded
Thank you in advance.
David
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: netgear nighthawk wifi 6 router rax120
Something to make contact with the PBX phone system Mfr and ask them for help and information regarding there product.
IF you set up any port forwarding configurations on the router, be sure to disable uPnP on the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi FURRYe38:
Thank you for reply, There was all configured on the PBX side, and it was worked fine with GrandStream router before I switched to Netgear nighthawk wifi 6. I don't understand even thought I enabled remote web management on and specify custom HTTPS protocol and port to device hosting IP address. but still got 403 Forbidden. I did contacted support but still haven't hear from them yet. I believes this is a poor design and it need to be fixed.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I did disable uPnP on the router. but it still didn't make any different.
Like i said this is a poor design and it's need to be fixed
- Mark as New
- Bookmark
- Subscribe
- Permalink
Try enabling uPnP, disable the PF configuration, and put the PBX device into the DMZ on the RAX router and see.
Something you'll have to contact NG support about if this all fails for you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
enabled uPnP, disable the PF configuration, and put the PBX device into the DMZ on the RAX router still say 403 forbidden https://192.168.1.253 tried without http still same
I guess the NG support didn't have any answer for me. waited over 30 days now.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
