× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
rax 45 unable to block porn website
route123
Hello,
I bought this product to block porn website for the home use,
it turns out that it only block the manually added porn website.
there are thousands of porn website and it is impossible for me to add manually.
what is the reason that  netgear dropped opendns solution that can effectively block the porn website?
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 6
Guru
Re: rax 45 unable to block porn website
Did you try using opendns's family shield setup? you can simply use the DNS address for the family shield.
FamilyShield Router Configuration Instructions – OpenDNS
Message 2 of 6
Did you check the specifications before you parted with your money?
Netgear makes a raft of routers, some of which are designed to do just what you want. But you have to pay for a subscription.
Unfortunately, the RAX40, unlike the RAX40V2, doesn't seem to be one of the devices that supports these features. Unless, that it, it has added them with new firmware. (This happens from time to time.)
Which products support NETGEAR Smart Parental Controls? | Answer | NETGEAR Support
What subscription plans are available for NETGEAR Smart Parental Controls? | Answer | NETGEAR Suppor...
Other devices support Circle:
Which NETGEAR routers support Circle Smart Parental Controls? | Answer | NETGEAR Support
Circle also needs a subscription.
What are the available service plans when using Circle Smart Parental Controls on my NETGEAR router?...
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Nighthawk Routers with WiFi 6 (AX) - NETGEAR Communities
Message 3 of 6
Good question.
NOTICE: Live Parental Control Service based on Ope... - NETGEAR Communities
Message 4 of 6
route123
Hi Michael,
My product is rax 45 and the parent control is supported.
Based on the talking with the netgrear support engineer, they didn't mention any subscription service.
they only offer to manually input the website to block. did I miss something?
thanks so much for the help
Message 5 of 6
Yes, but what sort of parental controls?
In its wisdom, Netgear keeps changing the names of these things.
The old free version of Parental Controls is dead or dying.
Live Parental Control | NETGEAR
But as @plemans suggests you don't have to use Netgear as an intermediary.
Home Internet Security | OpenDNS
Message 6 of 6
Discussion stats
  • 5 replies
  • 2030 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
