- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
rax41
- Mark as New
- Bookmark
- Subscribe
- Permalink
rax41
my rax41 NTP Settings very time you change it on the new hotfix 1.0.15.128_2.0.89 it dose not let you chage it i need to change it for my games is there a way to fxi it so that i can with out downing grading the firmware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: rax41
Hard to follow what you are saying there.
Where are you playing with the NTP setting?
Is it normal to have to change that for games?
Have you tried a factory reset with the new firmware?
How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
The factory reset is more a "witchcraft" move than a technically informed solution, but it does seem to fix problems. It is also the first thing that Netgear support will recommend.
- Mark as New
- Bookmark
- Subscribe
- Permalink
