× Introducing the Orbi 970 Series Mesh System with WiFi 7 technology. For more information visit the NETGEAR Press Room.
Orbi WiFi 7 RBE973
Reply
static connection setup D6400 modem to router AX5400
motofan
Follower
My internet led goes red every couple of days but I still have internet. If I turn off and restart the router it goes back to normal. May be I have setup the static address wrong. can anybody help me check if the static address is okay or at least help with the red led problem.
Model: RAX40|Nighthawk AX4 4-Stream WiFi Router
Message 1 of 3
Guru
Re: static connection setup D6400 modem to router AX5400
Be sure to check your modem for good signal from the ISP service.
I recommend bridging the D series modem since it already has a built in router. Having two routers on the same line can cause problems.
For RAX model support and information, Netgear has set up a community forum specifically for the NightHawk RAX WiFi 6 Router products. Most of the people who watch that forum are more likely to have experience with NH router products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Nighthawk-Routers-with-WiFi-6-AX/bd-p/en-home-routers-nighthawk-wif...
Thank you.
Message 2 of 3
If you want to get the most out of the RAX40, the last thing you want is the D6400 in modem/router mode. Faffing around with IP addresses isn't the solution. It should be in modem-only mode.
Be warned that if you do that you can expect problems if you have power cuts. With my D6400 in modem mode, it was so slow to boot up that the R7800 router behind it got fed up of waiting and timed out, leaving me with a dead network.
If you do hit this problem, and if you can lay your hands on something like the DM200 second hand at a reasonable price, leap at the chance.
Sadly, neither Netgear, nor most other brads, now makes modem only boxes. (A technician from my ISP said that they had told ISPs that they have to supply modem/routers.)
Message 3 of 3
Discussion stats
  • 2 replies
  • 623 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
