kfcote
Aug 15, 2020Follower
upload speed adjustment
I recently purchased the Nighthawk AX6 WiFi Router and it has really good download speeds (87 Mbps) but the upload speeds are only (7.92 Mbps). Is there a setting or way to increase the upload speeds? I have been working at home using MSTeams for meetings and running into bandwidth issues using video and audio in the conference calls.
1 Reply
Sort By
Which one?
kfcote wrote:
....but the upload speeds are only (7.92 Mbps).
What does your ISP say you should get? What do you pay for?
What firmware version do you have on the device?
A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
It might also help if you told people what the modem is in front of this router, if there is one. The model number could be useful. Is it, by any chance, also a router, with a set of LAN ports on the back?
