- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Netgear Nighthawk RS300
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi can anybody help I have tried Netgear support and they can’t fix my issue, I have just taken out my BT Home Hub2 router and replaced with a Netgear Nighthawk RS300 Firmware Version V1.0.1.60, I have FFTP and have never had any issues with my BT Router, I changed because I needed wi-fi6, so my problem is every day around about 08:30 my both my laptops (windows11) loses the internet, wi-fi says it’s connected but I cant connect to my email or web browser, however all other Wi-Fi devices work, Firesticks, smart TV,s cell phones, printer etc, I have to reboot the router to get the laptop back up, this is doing my head in please help.
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
By jove Furrye38 you have cracked my router problem so well done and a big thank you 😊
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Netgear Nighthawk RS300
Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
Is Protection Engine enabled on the RS routers web page? Under Advanced Tab/Administration/Security. If so, disable this feature, apply the change and reboot the router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Nokia Model Unknown as I said it has all worked OK with BT Home Hub 2 router
I have disabled Protection Engine
I will let you know after 08:30 UK time if the laptop kept the internet connected
Many Thanks Furrye38
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Furrye38, 08:30 my time has come & gone and I have not lost internet on my laptop you may have cracked it 🙂 I will wait until tomorrows 08:30 has come and gone to check all is still well. Many thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
https://kb.netgear.com/24231/How-do-I-back-up-the-router-configuration-settings-on-my-Nighthawk-rout...
Enjoy. 📡
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
