× Introducing the new Orbi 770 Series Mesh System. To learn more click here.
Orbi WiFi 7 RBE973
Reply
RS700:  Heat Management
Topology
Virtuoso
My understanding is that the Nighthawk RS700 Tri-Band WiFi 7 Router is not equipped with an internal fan, and relies only on passive heat dissipation.  How well is the router able to manage heat, under ‘normal’ and ‘heavy’ usage?
Do you use an external fan to circulate air through (or nearby) the router – and, if so, can you please share your experience together with the manufacturer and model of the fan?
Thank you.
Message 1 of 8
Guru
Re: RS700:  Heat Management
I use one of these for additional cooling under or on top of any router I put online:
https://www.amazon.com/gp/product/B08ZSJFNMS/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Message 2 of 8
Topology
Virtuoso
@FURRYe38, [1] are you using a fan with the RS700 router as a preventative measure, or because you have noticed the device becoming warm or hot without a fan?
[2] How do you position your 120mm USB fan to cool the RS700?  Does the router have open airflow slots on its bottom, and do you stand the router on the top of the fan in order to blow cool air up and into the router?
Thank you.
Message 3 of 8
Guru
Thought I don't have an RS yet, the fan is a " preventative measure" for ANY router I have online. One sits on top of my RBR971 currently and one sits under my RBR850 currently.
Message 4 of 8
Topology
Virtuoso
Individuals interested in using a fan to cool a router may wish to consider products by AC Infinity (e.g., see here and here).
Message 5 of 8
Guru
I've found the fan off Amazon to be well sufficent for additional cooling. Cheep too.
Message 6 of 8
Topology
Virtuoso
I am curious to hear from NETGEAR Community members about their experiences with the RS700 in regard to router's use of passive heat dissipation:  how well is the router able to successfully manage heat, under ‘normal’ and ‘heavy’ usage conditions?  (Thank you.)
Message 7 of 8
DavidDresh
Initiate
As a user, I've found that the Nighthawk RS700 router effectively manages heat under normal usage. However, during heavy usage or in warmer environments, it benefits from additional cooling.
Message 8 of 8
Discussion stats
  • 7 replies
  • 1390 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
