Orbi WiFi 7 RBE973
Reply
LBR20 lte port forwarding not working
styvy
Follower
hi everybody
i have configured port forwadins http: 8080   but not working on LTELBR20
do i need static IP or no  for LTE
if a test with other router with IPS modem cable  and open port 8080 is working
 do you knows why is notworking
best regard
Message 1 of 2
KevinLiT
NETGEAR Moderator
Re: LBR20 lte port forwarding not working
Hi styvy,
I understand that you would like more information to successfully implement port forwarding on your LBR20.
I have included steps below on how to port forward with the LBR20:
  • Select ADVANCED > Advanced Setup > Port Forwarding/Port Triggering. The Port Forwarding/Port Triggering page displays
  • Leave the Port Forwarding radio button selected as the service type.
  • Click the Add Custom Service button. The Ports - Custom Services page displays.
  • In the Service Name field, enter a descriptive name.
  • In the Protocol menu, select the protocol. If you are unsure, select TCP/UDP.
  • In the External Port range field, enter the port numbers.
  • Specify the internal ports by one of these methods:
  • Leave the Use the same port range for the Internal port check box selected.
  • Type the port numbers in the Internal port range field.
  • Type the IP address in the Internal IP address fields or select the radio button for an attached device listed in the table.
  • Click the Apply button. The service is now in the list on the Port Forwarding/Port Triggering page
For more information on port forwarding please navigate to the link below (page 122):
https://www.downloads.netgear.com/files/GDC/LBR20/Orbi_LBR20_UM_EN.pdf
Best,
Kevin
Community Team
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 645 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
