Orbi WiFi 7 RBE973
Reply
Backhauling Orbi SRS60 system
cdonston
Follower
I currently have the Orbi main router SRR60 with two SRS60 satellites.  I have recently built a barn approx. 200' away from my home.  I ran a network cable to the barn.  I would like to add an additional SRS60 in the barn and connect it to the network cable as well to improve speed and to make it hardwired.  Is this possible with these models.  I have done some research and read about "wired backhauling" and think that might be the solution.  Just not sure if my models are compatible.
Message 1 of 2
Guru
Re: Backhauling Orbi SRS60 system
Yes your models support a wired backhaul.
Wired backhaul is really a perfect setup when you're running that far as the wireless backhaul won't reach.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 681 views
  • 0 kudos
  • 2 in conversation
Announcements
