Orbi WiFi 7 RBE973
Reply
Cannot update latest firmware 2.7.2.102 SRR60 and SRS60
Stables
Initiate
Cannot do a manual update or automatic update from 2.7.0.122 to latest firmware
2.7.2.102 Auto update says "no new firmware update available" Manual update says firmware file is incorrect version....weird....
Message 1 of 4
Guru
Re: Cannot update latest firmware 2.7.2.102 SRR60 and SRS60
When you're manually updating, are you making sure the router is getting the router version and the satellite the satellite version? I know it sounds stupid but I've seen people trying to install the satellite firmware to the router. (also, make sure to update the satellite first).
Message 2 of 4
Stables
Initiate
Yeah....updated manually before on previous versions so doing everything right but no result. any other suggestions?
Message 3 of 4
Guru
You extracted the file prior to trying to upload it? (i know it sounds stupid but have to ask)
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1067 views
  • 1 kudo
  • 2 in conversation
Announcements
