- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
New Firmware V2.5.3.108 for SRR60/SRS60/SRC60/RBS50Y(for Orbi Pro) Now Available!
- Mark as New
- Bookmark
- Subscribe
- Permalink
New Features
- Guest portal now supports WPA2 mode
- Supports the NETGEAR Insight app and Insight Cloud Portal version IM-5.10
Bug Fixes and Enhancements
- Web server and OpenSSL package upgrade
- Fixes a DNS problem that intermittently causes loss of connectivity
- Fixes the issue where MAC ACL entries can be lost
- Fixes issue where the notification "curl_get Return code: 52" appears frequently in Insight app or Insight Cloud portal
- Fixes the issue where the third radio can stop working after Dynamic Frequency Selection (DFS) detects radar presence on a channel too many times
- Fixes the issue where the Insight app or Insight Cloud portal show incorrect information in the device dashboard page when there are multiple attached devices
- Fixes the issue where the password can be recovered only if the user name is 'admin'
- Updates the HTTP Certificate
Known Issues
- After updating router firmware, existing clients can be steered to the router because the wireless readiness in the router is faster than the wireless readiness in the satellite. Workaround: Connected clients might notice slower throughput or a weaker signal, which resolves when the user roams or reconnects.
Download Link
SRR60 - https://www.downloads.netgear.com/files/GDC/SRK60/SRR60-V2.5.3.108.zip
SRS60 - https://www.downloads.netgear.com/files/GDC/SRK60/SRS60-V2.5.3.108.zip
SRC60 - https://www.downloads.netgear.com/files/GDC/SRC60/SRC60-V2.5.3.108.zip
RBS50Y - https://www.downloads.netgear.com/files/GDC/RBS50Y/RBS50Y-V2.5.3.108.zip
Firmware Update Instructions
If the Orbi Pro is connected to the Insight cloud, perform a firmware update through the firmware schedule policy, or manually perform a firmware update using the Insight app or local browser interface.
To update the Orbi Pro firmware from the local browser interface, follow the instructions in your product’s user manual. To find your user manual, visit https://www.netgear.com/support/, enter your model number in the search box, and click Documentation on the product page. We highly recommend updating the satellite firmware first, and then updating the router firmware.
After updating to the latest firmware, make sure to update your version of the NETGEAR Insight app for the best functionality and user experience.
Additional Firmware Update Instructions for RBS50Y(for Orbi Pro)
The Orbi Outdoor (RBS50Y) uses different firmware versions depending on which wireless system you use. As of 2.3.5.22, RBS50Y detects whether the Orbi Router is an Orbi Pro system, and if so, automatically updates to Orbi Pro-compatible firmware.
If the firmware version is showing 0.0.0.0 on RBS50Y, the system is preparing to update to the Orbi Pro-compatible firmware.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
