- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
ORBI AC3000: Satelitte looses connection but does not reconnect
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Our system: ORBI PRO AC3000 with 2 Satelites (daisy-chained)
Firmware: V2.7.2.102
We have a system running in a remote location. The second satellite connects to the first satellite (daisy-chain). Even the connection is not perfect, it works stable for weeks. But then we noticed, the second satellite looses connection from time to time, but does not reconnect automatically.
We found a solution by resetting the Router which results in a new established connection from satellite 2 to satellite 1.
Even this works, this is not satisfying because we have to login to the remote system and reboot the router.
Why does a AC3000 satellite does not reconnect automatically? Should we install a time switch on satellite 2 to ensure a stable Internet in this building? Is this really needed in such a "Pro"-System?
Or have I overseen something in the configuration?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: ORBI AC3000: Satelitte looses connection but does not reconnect
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
My Setup | ISP SparkLight | Internet Cable 1000↓/50↑ CBR750 Modem | Wifi Router CBR750(v.7) | Switches NG GS105/8 and XS505M |
Additional NG HW: C7800/CAX80/CM1100/CM1200/CM2000, Orbi: CBK40, CBK752, RBK50, RBK853, RBK752, RBK953, SXK30 | NightHawk: R7000, R7800, R7960P, R8000, R8500, RAXE500, RAX50, XR450, EX7500/EX7700, GS308v3
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Router and Satelites run with Firmware V2.7.2.102
> What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
I can't proivde this info currently. The installation/buliding is 3 h travel away, that's my problem that I have troubles in this remote location
> What is the size of your home? Sq Ft? What is the distance between the router and 📡 satellite(s)?
It's a large multistory home (wood/concrete):
- Router on base floor
- Sat.1 on the first floor, about 10..12 m (32..35 ft) "bee line" distance (Signal Fair 79 dBm)
- Sat 2 on the third floor, about 11 m (32 ft) "bee line" from Sat 1 ( (Signal Fair 79 dBm, sometimes I see "poor")£
The question remains:
- Why doesn't a satellite connect automatically when it loses connectivity?
- Why do I have to manually restart the router and then it works again for some time?
- Do I have to install a timer on a satellite so that I can be sure that if the connection is lost, the system will restart at least 1x a day? Can such a function not be implanted in the firmware to provide a stable system?
We chose Orbi Pro because we want to have a stable system on sites.I'm grateful for any help/tip.
