Orbi WiFi 7 RBE973
Orbi Pro SXK80 with GS728TPv2 - VLAN setup
IDGAF12
Follower
I've just bought a Orbi Pro SXK80B4 with a Smart Managed Switch GS728TPv2
I'd like to have 4 different SSID's for wifi of the Orbi Pro, pretty sure that will work according to the manuals, but how do I 'patch' some hardwired devices (camera's) on the POE switch to the same network (SSID), which is managed in the Orbi.
Is there a way the switch can 'talk' to the Orbi and adapt all the network settings?
What's the best way to approach this?
Thanks in advace!
Ben
Message 1 of 3
CrimpOn
Guru
Re: Orbi Pro SXK80 with GS728TPv2 - VLAN setup
Using VLANs is discussed on page 233 of the User Manual:
https://www.downloads.netgear.com/files/GDC/SXK80/Orbi_Pro_WiFi_6_UM_EN.pdf
Was a support contract included with this purchase? (from the product description)
As this is a Power over Ethernet (PoE) switch, would it be correct to infer that the goal is to support security cameras?
My first impression is:
  • Pick one of the SSIDs for this purpose (not Guest)
  • Connect any WiFi cameras to this SSID
  • Assign one of the LAN ports to the same VLAN as this SSID
  • Connect the switch to that LAN port
  • I do not think the switch needs to have any VLAN settings.
Message 2 of 3
schumaku
Guru
The point is to have as many VLAN as you need for your design and deployment intentions. Multiple VLANs can be defined on a single trunk for implementing  trunk from the SX[R]80 resp. the SXS80 to connect a VLAN capable switch for example. On the switch and or on the Orbi Pro ports you can freely configure select ports to access ports, untagged and defined as PVID for the VLAN desired.
Message 3 of 3
Discussion stats
  • 2 replies
  • 932 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
