Orbi WiFi 7 RBE973
Reply
SXK80 VLAN DHCP helper function?
farkhispe
Follower
I have a homelab and bought the SXK80 router in hoping of fiddling around with VLANs more.
I run a Windows based DHCP server in Hyper-V.
My old network was 10.0.0.X, so when I brought my new network online I just enabled VLAN5 on the SXK80, made it 10.0.0.X, and then made other VLANs within the 10.0.X.X range.
The issue I'm running into is that while I can turn off DHCP on the SXK80's VLANs, there doesn't appear to be a means of pointing them to my Windows DHCP server, unless they're on that VLAN.
Am I missing something here?
Message 1 of 4
schumaku
Guru
Re: SXK80 VLAN DHCP helper function?
@BruceGuo please.
Message 2 of 4
BruceGuo
NETGEAR Expert
Good suggestion in AP mode. I have raised the ticket internally. We will prioritize the feature.
Message 3 of 4
schumaku
Guru
@BruceGuo in both AP and router mode. And add the possibility to define 1..3 devices on the LAN for serving DNS res. a DNS relay.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 1393 views
  • 2 kudos
  • 3 in conversation
Announcements
