Orbi WiFi 7 RBE973
Reply
Broadband upgrade question
kahoo614
Follower
Hello, currently, I have a 1000 Mbps broadband connection at home, and I'm planning to upgrade it to 2000 Mbps next month. I'm using the RBK752 Mesh WiFi system. Will it be able to support the 2000 Mbps broadband?
If not, is it possible to upgrade only the main router and repurpose the existing RBR750 router and RBS750 satellites as satellites?
Hello, if you currently have a 1000 Mbps broadband connection at home and plan to upgrade it to 2000 Mbps next month, you are using the RBK752 Mesh WiFi system. You would like to know if it can handle the 2000 Mbps broadband.
If it is not capable, you would like to know if it's possible to upgrade only the main router and convert the existing RBR750 router and RBS750 satellites into satellites.
Message 1 of 2
CrimpOn
Guru
Re: Broadband upgrade question
The RBR750 router WAN port supports 1GB.  Upgrading the Internet connection to any speed higher than 1GB is pointless because the Ethernet connection  tops out at 1 GB.
The Orbi RBS750 satellites are compatible with a different Orbi router.  See this page:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 167 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
