Orbi WiFi 7 RBE973
Reply
CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7) dropped downloads speed!!!
atejwani
Apprentice
Prior to CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7), I was consistently getting 1.2gb - 1.4gb download speeds. Now it is below 650mb. Nothing else, besides the firmware updates, has changed.
Netgear Team - Kindly review firmware and provide a fix!!!
Message 1 of 22
Guru
Re: CBK 752 Firmware updates (CBR750 -V4.6.3.6, RBS750 -V4.6.3.7) dropped downloads speed!!!
Please open a support ticked with NG support and let them know what your experiencing. Can reference this forum thread as well.
Thank you.
Message 2 of 22
atejwani
Apprentice
I wish I could! I've had the CBK752 (CBR750/RBS750) since November 2020, and besides Hardware, I am outside the "warranty" window:
Product Warranty Information
Product: CBRXXX
Country of Purchase: United States
Purchased on: 2020-11-26
Standard Product Warranty:
Hardware Warranty: Available till 2021-11-26
Phone Support: Expired
Email Support: Expired
Chat Support: Expired
Message 3 of 22
Guru
Please reach out to a forum moderator to see what options are available for you.
@Christian_R @Blanca_O
Message 4 of 22
Blanca_O
NETGEAR Moderator
Hi @atejwani
May we please know who is your Internet Service Provider?
Please check your inbox. I have sent you a message requesting for more information.
Blanca
Community Team
Message 5 of 22
atejwani
Apprentice
Answers below in Bold.
@Blanca_O wrote:
Hi @atejwani
Xfinity - Comcast - Service: 1.2gb Down/40mb Up
Replied to private message.
Blanca
Community Team
Message 6 of 22
Guru
Message 7 of 22
cin8
Tutor
Hello, did you get this issue resolved? I'm having the same exact problem after the firmware update. Seems from the research I've been doing, will just have to wait for another FW update.
Thank you!
Message 8 of 22
Guru
@Blanca_O @DarrenM
Thank you!
Message 9 of 22
cin8
Tutor
Thanks! I found a tip on another thread about this. It suggested to connect a laptop or desktop directly via a LAN port on the CBR750 and test the speed through the Speednet app. I used the Windows download of it. The speed was accurate. No significant drop. I'm not too concerned anymore about the inaccurate number through the Orbi app or the onboard web interface.
Message 10 of 22
cin8
Tutor
Have still reached out to the forum moderators for the Beta bc the CBR750 has been rebooting on its own several times a day now.
Message 11 of 22
atejwani
Apprentice
Hello Blanca and Darren
@Blanca_O
@DarrenM
If there this beta firmware for CBK 752 (CBR750/RBS750) please include me and send or point me to the beta firmware. I can definitely assist in regressoin testing before it is publicly rolled out.
Thanks,
Al
Message 12 of 22
cpmassen
Apprentice
Looking for a beta firmware for the CBR750 also. Thanks
Message 13 of 22
Guru
Hopefully NG will come out with something. Please be patient.
Message 14 of 22
cpmassen
Apprentice
Thanks.  Was just posting in this forum so I could get update notifcations for new posts
since you directed me to it.  I wasn't aware it existed.
Message 15 of 22
Guru
Message 16 of 22
atejwani
Apprentice
Hello Blanca, Darren and Furrye38 - @Blanca_O , @DarrenM , @FURRYe38 ,
It has been about 6 weeks since these firmware upgrades were introduced and have degraded performance of our modem router/satelite. I have spent several hours with Netgear support personnel, who have just asked for more and more logs and I have not seen a solution from them. For now, I have given up on Netgear Engineering/R&D/Support providing any update firmware, be it beta.
There are bits and pieces of from various users, spread across various Netgear Orbi products - RBK752/3. RBK852/3, RBR750, RBR850, RBS750, RBS850,CBR750, CBR40, etc. and "rolling" back firmwares to prior versions on Netgear Community posts and Reddit posts!!!
Can Netgear Support to put together a "FAQ" with steps, which versions of firmware to "roll-back" to, and specific to the products, such as CBK752?
Thanks in Advance,
Al.
Message 17 of 22
Guru
You'll need to contact NG support and open a support ticket.
https://www.netgear.com/support/#
Message 18 of 22
Guru
Message 19 of 22
rmarcare
Apprentice
Were your issues fixed or did you replace the setup?
Message 20 of 22
cpmassen
Apprentice
I’m still having issues with the satellite connecting to my Samsung TV. Tonight the tv was connected and upon researching it the Satellite was out of sync. As soon as I synced the satellite back the TV immediately lost connection. I’ve reported it and tried everything and no fix supplied at all yet
Message 21 of 22
cin8
Tutor
Not sure if you tried this yet, but the satellite also has a factory reset pinhole. I previously had issues with my satellite and factory reset it and haven't had an issue since. Also, if there's a delete button next to the satellite listing when you view the connected devices (through the webpage), I would go ahead and delete it too.
I am on all of the current firmware and after factory resetting both modem/router and satellite, I've had over 30 days of uptime.
Message 22 of 22
Top Contributors
Discussion stats
  • 21 replies
  • 4186 views
  • 4 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
