Orbi WiFi 7 RBE973
Reply
Co-existence of RBR50 with RBK752
whisquer
Thinking of upgrading my RBR50 with 2 satellites to an RBK752 wifi6 system. Can the RBR50 work in the same mesh network as the RBK752 to improve coverage through my thick concrete walls, and any reasons why this wouldn't be a good idea? Thanks, such a newbie at this.
Message 1 of 4
Accepted Solutions
Guru
Re: Co-existence of RBR50 with RBK752
No, they are not compatible.
Message 2 of 4
All Replies
Guru
Message 2 of 4
Guru
If you have a chance to hardwire it in (the rbr50), you could use the 50 series in access point mode. That'd let you use it in conjunction with the newer system but it wouldn't integrate with it.
I'd set it with a separate ssid so its not creating interference with the AX system.
Maybe have one system cover one side of the home that uses more bandwidth and the older system the other side.
Message 3 of 4
whisquer
Many thanks!
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 577 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
