- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Connecting RBS850 to RBR850
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have problem with connecting new RBS850 to my RBR850. I bought second satellite, and can't connect it. Even when there is info about successful connection, the satellite isn't visible.
Also when I try to reconnect my current satellite (also RBS850), after pressing reset button (until amber light blinks), and then clicks reconnect in the attached Devices, it somehow connects back after a while.
After resetting whole device, and setting up a new network, the old satellite is connected right away, and with the new one same problem, after information about successful connection it's not on the list of devices
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possible that the new RBS is not on same FW version level as your current units. If this is so, you'll need to connect a ethernet connected PC to the back of the RBS and no sync it, wait about 5 minutes. Set a static IP address on your PC for 192.168.1.49. Then see if you can access the RBS web page at 192.168.1.250. if you can, log in with admin and "password". Have the same level RBS FW version file unpacked on the PC and use the RBS web page to upload it to the RBS.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Connecting RBS850 to RBR850
When a package is created at the factory, router and satellite are paired, which makes initial setup much easier. Depending on where the new satellite came from, it may have previously been paired to a specific router. It might help to do a Factory Reset on the new satellite (paperclip, power LED flashing amber, etc.) before using the Orbi web interface menu item Add Orbi Satellite.
Can you please explain more about "after information about successful connection"? Is this a pattern of lights on the satellite? A message on the Orbi web interface?
I typically look at the Attached Devices display where the top panel shows satellites and the bottom panel shows devices that are connected to the system.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The first satellite was a pair (RBK852), so that explains self connection after factory reset. But should it also automatically pair when I reconnect only the satellite after pressing reset button on device and clicking reconnect in settings?
But back to the main problem, on the new satellite which I want to connect I did factory reset, by pressing reset button on device until amber light blinks. After that the light in front starts flashing (white) and after some time lights still (also white), then I press sync button on the back, and in "add orbi satellite" logging to settings by browser. After a while appears a message "satellite setup successfully" the device the light shines blue, however going to Attached Device I see only my old satellite. I try it several times resetting satellite again, and every time the same.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Attached Devices display does not update instantly. What happens if you wait 15 minutes and open Attached Devices again?
- Mark as New
- Bookmark
- Subscribe
- Permalink
nothing, even after the whole night I don't see it, rebooting also doesn't change anything
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would be fascinating to see if a device wired to the new satellite can access the internet.
(sigh) I realize this is becoming dificult as more and more users have zero devices in the house with Ethernet jacks.
Some models of smartphone and tablet display the hardware MAC address of the WiFi access point (at least my Samsung Galaxy Tab S6-lite does).
- Mark as New
- Bookmark
- Subscribe
- Permalink
This is beyond me😄
however I did this different way. Connected to router by cable, search in attached devices, look what IP address is, login that way, and updated. After that it appeared as a satellite.
So thanks for help, I couldn't deal with it on my own.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Glad you got it working. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
