Orbi WiFi 7 RBE973
Reply
Connecting a Nighthawk X4S WiFi Range Extender Wall-Plug to an Nighthawk AC2200 WiFi Access Point
hankdogg
I have two Nighthawk X4 (AC2200 - model EX7300) WiFi Extenders at various locations in my house. Each one is set up as an access point vs. as an extender and each one is connected via ethernet cable to a Nighthawk X6 (AC3200) router. All items have updated firmware and are working just fine, each having their own SSID.
My situation is this: I want to add a range extender in my backyard gazebo so I have better reception for streaming video to devices out there (the gazebo has a power outlet which is +/- 50' away from the nearest access point).
My question is: Can I connect a wall plug extender like the Nighthawk X4S in the gazebo, or maybe even another X4 (AC2200), and get it to link up wirelessly with the nearest X4 (AC2200) access point?
Model: EX7300|AC2200 Nighthawk X4 WiFi Mesh Extender, EX7500|AC2200 Nighthawk X4S Tri Band WiFi Mesh Extender
Message 1 of 4
Accepted Solutions
Guru
Re: Connecting a Nighthawk X4S WiFi Range Extender Wall-Plug to an Nighthawk AC2200 WiFi Access Poin
Netgear has set up a community forum specifically for the WiFi Extender products. Most of the people who watch that forum are more likely to have experience with WiFi Extender products and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/WiFi-Range-Extenders-Nighthawk/bd-p/home-wifi-range-extenders
Thank you.
Message 2 of 4
All Replies
Guru
Thank you.
Message 2 of 4
hankdogg
Thanks. I noticed that after I posted but couldn't seem to find an option in the editor to change the location.  Should I just copy and paste into the other forum?
Message 3 of 4
Guru
Yes.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 995 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
