- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Costco Orbi w/ 2 satellites RBK753S AX4200
- Mark as New
- Bookmark
- Subscribe
- Permalink
Costco is selling this model for $399.99 with two satellites.
I just bought the AX6000 Orbi model from Best Buy for $699 with only one satellite. That's a huge price difference. Would I notice a difference in performance if I return the Best Buy orbi and purchase the cheaper one from Costco?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Costco Orbi w/ 2 satellites RBK753S AX4200
Is the 8 series not working well for you?
Most differences are wifi connection rates are a bit lower on the 7 series and there isn't a 2.5Gb WAN port on the 7 series.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Not everyone is having the same issues. If your having problems with your system then you'll need to contact NG support and open up a support ticket.
https://www.netgear.com/support/#
Good Luck.
@AggedwNG wrote:
In case you haven't noticed, LOT of issues with recent fw.. My suggestion, get the one at Costco, minimize your risk. Costco has a better return policy than Best Buy, which will count considering the gamble with the latest firmware
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Then you'll need to contact NG support and let them know what your having problems with. Not everyone has the same issues and you can't know what other use do and do NOT see and experience and claim its all the same. I agree, v4 has been problematic from the start, however we DON'T assume anything here in the forums. Take each user and handle them for what THEY describe. IF we can't help them then its users resposibility to contact NG support and seek additional help and information. If nothing else works out, then return the system to place of purchase and go find something else that does.
Good Luck.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You'll need to contact NG support and open up a support ticket as the forums can't seem to help you out.
Good Luck.
