- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Download slower than upload Orbi RBKE963
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please help!!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Download slower than upload Orbi RBKE963
"Slower" as in:
- A few megabits difference, or
- 100's of megabits difference?
Is the Orbi in router or Access Point (AP) mode?
- Mark as New
- Bookmark
- Subscribe
- Permalink
It is 1000ish down/200ish up. I had my friend confirm and he has 1Gb both up and down.
It is setup as a router.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If it really is 1000 down and 200 up, I would not be concerned (who has that much to upload?)
Doesn't AT&T have a speed test on their phone 'app' that reports up/down speed to their unit?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Elsydeon wrote:It is 1000ish down/200ish up. I had my friend confirm and he has 1Gb both up and down.
Is the CR1000A in bridge mode? If not, while using the Orbi as a router then you have 2 routers operating and Double NAT. Suggest trying the Orbi in AP mode or else put the CR1000A in bridge mode.
I also agree with the other post - These speeds are already far more that anyone needs. 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thank you for your assistance.
Is it normal for an Orbi connected to a Verizon modem to get 850 down/150 up on a 1Gb connection?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
https://www.verizon.com/support/verizon-router-cr1000a/
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-...
I would try option #2 first. Be sure your using a good quality LAN cable between the modem and router. CAT6A STP is recommended.
IF your getting hear 900Mpbs and near 200Mpbs thru the Orbi system, then it would be working as expected.
- Mark as New
- Bookmark
- Subscribe
- Permalink
The connection we are paying for is 1Gbit both upload and download.
Is the Orbi unable to do more than 200 up?
- Mark as New
- Bookmark
- Subscribe
- Permalink
With a wired PC connected to the 1Gb LAN port should see near 900Mpbs or just over.
Wireless depends on the wifi device and it's supported MIMO antenna and connetion rate support. Most 2x2 MIMO devices top out at around 600-700Mpbs. 4x4 MIMO devices can see 900Mbps and over.
Be sure your speed testing at the ISP Modem first and your getting speeds at the modem with a wired PC.
Try the Orbi system in AP mode with the ISP modem in router mode with it's wifi fully disabled.
Check the LAN cable between the modem and RBR.
