Orbi WiFi 7 RBE973
Reply
Firmware update RBK853 stuck on 3.2.18.1
Beertje
Follower
I have an Orbi RBK853. If I run a manual check of the firmware version, it says no updates are available. I run on 3.2.18.1. I doubt whether to do a manual update because I read about quite some issues with the new firmware 4.6.3.9. Can anyone recommend what to do, especially given the security fixes in the latest version?
Message 1 of 3
Accepted Solutions
Guru
Re: Firmware update RBK853 stuck on 3.2.18.1
I recommend keeping v3 loaded for now. Some have seen problems with v4 loaded. If v4 isn't seen by the RBR, you can manually download and manually install the FW files if you want to update. Update the RBS first then RBR lastly.
Message 3 of 3
All Replies
Guru
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
Message 2 of 3
Guru
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 675 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
