- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Issues with connections
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have a continued issue with my router since purchase that I cannot seem to figure out how to solve myself.
The internet on the Orbi (both WiFi and ethernet) seems to constantly go in/out. My computer is connected via ethernet and when I try to go to a website, it will occasionally say that I am not connected, to then refresh and connect to the page. But the real issue and concern is the Apple products I have. The internet on the phones and iPad will just stop working, and the only solution to the problem that I have found is to turn WiFi on my device off and back on. And it will then work for the program. But it is getting really annoying everytime I open an app to have to go into settings and do the off/on cycle. Any suggestions or ideas? (and no it is not an internet stability issue as I have no issue with my WiFi phone or work computer staying connected to the internet when I work from home).
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Issues with connections
For my modem, it is a Netgear CM1000v2. And the Orbi connects to it via ethernet. And both have the newest version of the firmware.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CastaCures wrote:I have a continued issue with my router since purchase that I cannot seem to figure out how to solve myself.
Netgear provides 90 days of "complimentary support" with the purchase of an Orbi system. How long have you had this system?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CastaCures wrote:For my modem, it is a Netgear CM1000v2. And the Orbi connects to it via ethernet. And both have the newest version of the firmware.
When was the latest orbi firmware installed?
was everything working before the update?
firmware version?
- Mark as New
- Bookmark
- Subscribe
- Permalink
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
What channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M970...
You can find other speed diagnosis steps in the community faq: https://community.netgear.com/t5/Orbi-AX/Community-FAQ-My-Orbi-speeds-are-slow-inconsistent-and-don-...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please let us see the answers to the questions I ask before you pepper them with 1000 questions
- Mark as New
- Bookmark
- Subscribe
- Permalink
Firmware is the most current at V3.2.16.22 and the issue has persisted since I installed the system 3 months ago. I bought it on 12/8, and I finally got sick of it and tried to find the fix now only to discover my 90 days were up and I have no support. My neighbors all live far from me so I do not pull their WiFi and it is the only network in the house. I am in the same room or within 60feet of the routed at all times. And again the issue occurs even with deviced connected via ethernet.
- Mark as New
- Bookmark
- Subscribe
- Permalink
So what modem Orbi AX do you have?
There is a newer version of FW for Orbi AX than what you have.
Please visit and post about this over in the Orbi AX forum:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried this solution and it seems to have fixed my issue. At least it seems fixed. I will give it a while to see if the problem doesn't reapper or persist. But since changing my settings as instructed in this post, everything has worked without me having to turn off/on the wifi settings on my devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Be sure to do a backup configuration to file for safe keeping if it works well for you. Saves time if a reset is needed.
Enjoy.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@CastaCures wrote:Firmware is the most current at V3.2.16.22 and the issue has persisted since I installed the system 3 months ago. I bought it on 12/8, and I finally got sick of it and tried to find the fix now only to discover my 90 days were up and I have no support. My neighbors all live far from me so I do not pull their WiFi and it is the only network in the house. I am in the same room or within 60feet of the routed at all times. And again the issue occurs even with deviced connected via ethernet.
Looks like your post will a better response here
enjoy.
