- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Location of mounting holes on bottom of RBS760 vs location on RBS750?
- Mark as New
- Bookmark
- Subscribe
- Permalink
How does the location of the mounting holes on the bottom of the RBS760 compare with the location of the mounting holes on the bottom of the RBS750?
Background: I cannot find wall mounting brackets for the RBS760 satellite unit. So, I'm contemplating using a RBS750 wall mount bracket with a RBS760 satellite unit. But, I don't know if the mounting holes are in the same location.
Your feedback is much appreciated.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Location of mounting holes on bottom of RBS760 vs location on RBS750?
I believe the case style is different from the 750 series.
https://www.downloads.netgear.com/files/GDC/RBK763S/RBK763S_DS.pdf
So I can only presume that the bottom screw holes maybe slightly different locations on the bottoms.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I agree with @FURRYe38 that the 750 and 760 are definitely "different":
RBS750:
RBS760:
Many of the current wall mounts on Amazon have a design that lends itself to "drill your own holes" if the bracket does not line up exactly with the case, such as this one:
This one looks like the mounting screws are almost redundant:
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi @FANOFTHE9
The RBS760 doesn’t have mounting holes. It is much smaller than the RBS750.
If you have the RBKWM (Orbi Wall Mount Kit), you would need to use the cradle which is used for smaller Orbi models.
To know more: https://www.netgear.com/support/product/rbkwm.aspx#docs
Blanca
Community Team
