- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
My RBR750 Orbi drops certain devices
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the same issue with my RBR750.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: My RBR750 Orbi drops certain devices
Would help to know exactly what the issue is. (see post #2 above).
Sometimes adding onto a conversation that has not progressed since August 7 (19 days ago) is not effective.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Some devices that were previously connected to Orbi are getting disconnected from network. If I try to reconnect, it says incorrect password even the correct password was saved before on that device. After rebooting the Orbi, the problem is solved temporarily. The same thing will happen after sometime.
- Mark as New
- Bookmark
- Subscribe
- Permalink
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
