Orbi WiFi 7 RBE973
Reply
My orbi wont connect at all
vsoks4200
Follower
Hello,
I just installed my 3 Orbi product as well as 4 additional units.
The main router is hardwired to my modem. And all other 6 units a localised wihtin 300 m2.
When the app starts up it asks to scan my QR code whic i do. Then it generates an ORBI58 wifi network, but this network doesn´t really work. As in, when I test the speed it is zero.
Then the app proceeds to try to connect to other units, but even though the units af just beside the router it doenst find any and just comes up with a screen that maybe the units are too far away, though they are right next to the router.
How can I fix this ?
Nigel
Message 1 of 5
Guru
Re: My orbi wont connect at all
What model Orbi do you have? RBK###?
Message 2 of 5
vaoks4200
The model 850 ax
My Home is around 3300 sqm and The svarskrift distance beyween units are around 50 sqm
Apart.
Du you have any suggestions to get the system
Working ?
Message 3 of 5
vaoks4200
The manufacturer is Cisco. The service provider is a company in Denmark
Message 4 of 5
Guru
I recommend setting up the RBR and RBS using a wired PC and web browser.
Power OFF the ISP modem and RBR for 1 minute then back ON after connecting the RBR to the ISP modem. Then walk thru the setup wizard at 192.168.1.1.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 758 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
