Orbi WiFi 7 RBE973
Reply
Netgear RBS850 still keeps going magenta
David9
So I reported this previously (but hell if I can find the previous posting). I have an RBS850 orbi solution with one satellite. It is over a year old (so has hardware support but bugger anything else) and it is still periodically going magenta.
Now the home internet is stable. there are NO issues there because I can continue to use it but the wifi via the router becomes unpredictable. It appears to work but can appear slow.
In short it seems there is a conflict somewhere. I am running it in AP mode because I was advised by Netgear support (when I had it) to do so.
Any thoughts?
btw I've tried resetting everything multiple times. Sometimes it will go for weeks without issue and then others it will recur several times over as many days.
...and no it is not a device issue. Don't even!
thoughts?
Message 1 of 11
Guru
Re: Netgear RBS850 still keeps going magenta
In AP mode, the router is getting its wan/ip info from the primary router its connected to. The magenta is indicating there's an issue with that.
What do the LEDs on my Orbi router and satellite mean? | Answer | NETGEAR Support
Maybe you're lease time is expiring on the router that's acting as primary. Maybe go into it and set it with a static IP address.
Now you put the RBS is going magenta. Just the satellite or the router too?
Message 2 of 11
Guru
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
https://kb.netgear.com/31030/What-do-the-LEDs-on-my-Orbi-mean
Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
Turn off and unplug modem.
Turn on computers and rest of network.
Any thoughts?
thoughts?
Message 3 of 11
David9
Thank you. I have already set the IP address of the Orbi router to be static and it still occurs. It is the router that is going magenta.
Message 4 of 11
David9
Firmware on the orbi is V4.6.14.3_2.3.12, which is apparently the latest release.
The service provider (TPG here in Australia) is a HUAWEI Home Gateway HG659 for Fibre to the Premises (FTTP).
The cable is the provided cable with the orbi router.
Yes I have powered off both the provider modem, the orbi router and the satellite as that is the only way to resolve the issue. It then can operate for a day, some days or even weeks without recurring....but it does and will still recur.
Message 5 of 11
David9
To add a little more. It has now happened again at least 3 times today. What I have noted is that the wired seems to be working but can be a little flaky. Mostly it seems to be DNS related.
I've also noted that the netgear itself seems to flick between "waiting" and "not connected" all throughout things are working but not quite working properly. there is slowness and errors when trying to get to things. most things work....
I'm about to reboot everything for the fourth time today. Hopefully it settles after that.
Message 6 of 11
Guru
If the internet keeps going down on the RBR then the RBR is only reporting that it can't get connected or not getting anything from your ISP gateway. You'll need to have the ISP check this gateway for good operation and signal up to it.
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-...
Message 7 of 11
David9
So i've said this a few times now. The internet from my PC cabled directly to the ISP modem does not experience any issues during the time that the Orbi router is experiencing the issue. It is also worth noting that the wifi via the orbi does still intermittently work.
I've worked with double NAT in the past and that is not a workable solution. I also need to reiterate that based on Netgear support advice the Orbi solution is NOT running in router mode but is already in access point (AP) mode and not routing.
So option 3 is already the configuration I am running.
Message 8 of 11
Guru
Any progress on this?
Message 9 of 11
David9
At this point I have not currently changed the configuration. It is currently stable but as I said it may recur within hours, days or possibly weeks. I am following up with the provider at this stage.
Message 10 of 11
Guru
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 845 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
