- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nintendo switch won't connect to rbr750
- Mark as New
- Bookmark
- Subscribe
- Permalink
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nintendo switch won't connect to rbr750
Can you please describe which step fails during setup:
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Infocynic wrote:
I just did a factory reset and it seems like it's ok now.
Good to hear. FYI - I don't think you should ever need to disable WMM and nor does it improve compatibility with older devices, so suggest putting it back and seeing if things still work for you. Older 2.4Ghz devices are sometimes made more compatible with Orbi by setting CTS/RTS Threshold to 2347 or unchecking AX mode (but not disabling WMM).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
