Orbi WiFi 7 RBE973
Reply
No coax connector.
copieguy54
Follower
No coax connector.
Ihave a model RBR750 router that does not have a coax connector. Instead it has a yellow ethernet connector labeled Internet. Do I need to order something else to make this work. My Spectrum modem has a coax connector on it.
Message 1 of 2
Accepted Solutions
Guru
Re: No coax connector.
The RBK system doesn't have a built in modem be design. the CBK systems are systems with built in cable modems.
You can connect your RBK system ot your ISP cable modem. Contact the ISP for help and information regarding there modem.
Use the Installation and User manual guides for help and information on setting up the RBK system.
Visit the Orbi AX forum for additional information regarding the RBK7 series system:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Good Luck.
Message 2 of 2
All Replies
Guru
Good Luck.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 1624 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
