- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi 6E Brand New slow Web?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have ~140 devices on my Orbi. Subnet is 255.255.255.0 so all devices are of the form 192.168.1.*
The Web Interface is dog slow? What gives? It took me 30 minutes to setup Reserved Addresses for about 13 addresses. Why?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi 6E Brand New slow Web?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What browser are you using? Happens with other browsers?
Try a different PC to compare?
Wire or wireless connection with the UI?
Wow that many devices. Wheew...maybe bogging down the UI...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hardware Version RBRE960
Firmware Version V6.3.7.5_3.2.25
Just bought Orbi a couple weeks ago so this has to be newest (I hope). Some devices did not re-connect -- I'm up to 145 devices now all on 192.168.1.* 255.255.255.*
I'm using the Cable that came with my new Orbi to connect my modem to NG. Is this one good enough? I have some extra (gold) ones I could replace it with -- but I figured I would just use the one that came in the box.
The model -- well -- right now I'm not sure but I will check.
The App behaves fine by the way with showing all the devices I have -- its just the web that is dog slow.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Also.....I got the 3 device 6E (black edition not that this matters :). So, 1 Router and 2 Sat
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Chrome and Firefox both behave the same slow way.
Wireless connection.
Only from one machine so far (laptop) I can try another
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Will307 wrote:I have ~140 devices on my Orbi. Subnet is 255.255.255.0 so all devices are of the form 192.168.1.*
The reserved addresses UI is very slow. I have ~80 and it takes ~10 sec after you press Add and then Edit for each additional one. It's just a flawed implementation, has nothing to do with wifi/ethernet/ISP speeds.
- Mark as New
- Bookmark
- Subscribe
- Permalink
You would think they would fix that.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have you tried newer version of FW?
Does same thing happen with this version?
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'm already on the newest per the UI anyway
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, some FW update may not be seen by the router.
That's the version prior.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Your right. Seems they are up to v6.3.7.10. I will give it a try.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Let us know if this still happens...
- Mark as New
- Bookmark
- Subscribe
- Permalink
I upgraded my router and this resulted in no change to the performance of the web. Still as slow as it was. Also, I could only upgrade the router (see below). If I attempted to upgrade the satellites I get an error 'cannot upgrade' so they are still at the lower version?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please use the manual method to update the RBS FIRST before the RBR. Log into the RBS web page and send the FW update for the RBS there...
- Mark as New
- Bookmark
- Subscribe
- Permalink
Yep. I upgraded the sats -- still dog slow.
- Mark as New
- Bookmark
- Subscribe
- Permalink
