Orbi WiFi 7 RBE973
Reply
Orbi (760 and likely others) satellites with ethernet backhaul do not sync guest network settings
cleishm
New owner and user of Orbi router and satellites (760 series).
I just encountered and diagnosed an issue with guest network settings not updating correctly around my network - a change to the guest SSID was not being broadcast by a subset of my satellites. I used NetSpot wifi analyzer to confirm this.
After much fiddling around, including some factory resets, I realized that allowing the satellites to connect via a wireless backhaul resolved the issue. Once resolved, I could reconnect the ethernet and return to a wired backhaul.
I suspect this is a bug, and I have seen other posts suggesting satellites do not broadcast the guest network. I have determined that this is definitely related to them being on an ethernet backhaul, and resolved by (temporarily) using a wireless one.
A bit disappointed that such a bug exists, and makes me concerned as to what else is inadvertently disabled when on a wired backhaul.
Message 1 of 5
iyang
NETGEAR Expert
Re: Orbi (760 and likely others) satellites with ethernet backhaul do not sync guest network setting
Hi @cleishm ,
What's firmware do you use ?
How many satellite do you use ?
Thanks
Message 2 of 5
cleishm
Whatever the latest firmware is (updating was part of my debugging effort), and 3 satellites.
Message 3 of 5
Guru
Is there a specific FW version?
Message 4 of 5
cleishm
V6.3.6.4_1.2.68
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 465 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
