- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi 960, single router only?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Why does Netgear force you to purchase a minimum of two units (router and satellite)? Not all applications require that. Is there some "technical" reason this is necessary that I've not discovered?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi 960, single router only?
My guess is no one at Netgear expected to have enough customers wanting to purchase a "mesh" system without any satellites to create and stock such a product.
Netgear offers numerous WiFi routers. The distinguishing characteristic of the Orbi product line is the "mesh" capability, where one router and one or more satellites are connected to create a larger seamless WiFi coverage than a single WiFi router can. There are strict limits on the strength of WiFi radio signals and the only way to extend coverage is to install more WiFi access points.
A single RBRE960 router with zero satellites has no advantage over a single WiFi6E router.
A single RAXE500 is the functional equivalent of a single RBRE960.
The only significant differences (that I see) are:
- The RAXE500 has two functioning USB ports which can be used to connect printers or USB hard drives, while the RBRE960 has no USB ports.
- The RBRE960 features Netgear's Parental Controls, which is not mentioned in the RAX500E Product Data Sheet:
If controlling your parents is important, then the RAXE500 is not the right product.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I understand your point, well taken. But it's not really another product -- it's just the router. And we can expand into a mesh later when we need to. I think that's reasonable.
As for the signal limitations, I remember (way back) where you could hack the Linksys 802.11g signal beyond legal limits - I had amazing coverage 🙂
Thanks for responding.
Updating my reply. I went to Amazon to do some price comparison shopping and here I found:
NETGEAR Orbi Quad-Band WiFi 6E Router (RBRE960)
searching on Netgear's site, I found:
So I interpret this tactic as they would prefer you buy more, but have less available, if you're willing to dig and look for it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry, I meant another product in the sense of:
- Different packaging
- Different part number
- Managing inventory (how many to stock, when to reorder, etc. etc.)
