- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi Network
- Mark as New
- Bookmark
- Subscribe
- Permalink
Orbi Network
I have my own Netgear router/Modem and a Orbi 6 mesh with Satellite can I use the same network name for both of them, my security cameras run on the Netgear network but it switches to the Orbi network and I loose my cameras
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi Network
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/000061277/Which-features-are-disabled-on-my-Orbi-router-when-it-is-set-to-AP-...
Try option #2 first...
