- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Orbi RBK852 and satellites- service keeps dropping
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello- I have an Orbi RBK852 with three wired satellites (we just moved into an old house with insanely thick stone walls that was blocking the signal when we tried to use them as wireless, and I need one wired connection for my work computers for security issues). We have Verizon Fios service which was recently installed around 4 days ago. The internet connection drops sporadically for approximately 15-20 min at a time multiple times a day, which is incredibly annoying as then my work VPN gets disconnected and the entire computer crashes. I called Verizon and they claim there hasn't been any connectivity issues on their end so I have to think it must be the Orbis. Does anyone have any insight into this??? Thanks in advance.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Orbi RBK852 and satellites- service keeps dropping
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 📡
How are the RBS connected to the RBR via ethernet? Directly to the back of the RBR or is there a LAN switch in between them?
What CAT# lan cable are you using? CAT6 is recommended.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Current firmware version is V4.6.8.2.
I just have the Orbi router connected directly to the FIOS cable. When I called Verizon they said not to connect two routers because it would confuse the service (?)
The house is 3000 sq feet but with very thick stone walls which is why I connected the RBR with the 3 RBS (directly, no LAN switc h.
Using CAT6 cables for every connection.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
