Orbi WiFi 7 RBE973
Reply
Orbi RBR-752 ethernet port issue
vics-orbi
I have a Orbi-752 which is about 3 months old. I have been noticing that the ethernet ports keep on dropping the connection intermittently, specially when I do speed tests. I have CenturyLink 940Mbs fiber connection and I am using the Orbi directly, meaning not using CenturyLink's router.
Any suggestions ?
Thanks
Message 1 of 4
Accepted Solutions
Guru
Re: Orbi RBR-752 ethernet port issue
Does the front LED turn at anytime whent this happens?
Do all LAN ports in back experience this?
Does wireless still work?
What kind of LAN cabling are you using? CAT6 is recommended.
Be sure to check for bad cabling as well. Swap LAN cabling to test.
Message 2 of 4
All Replies
Guru
Message 2 of 4
vics-orbi
It seems that it was cable issue. Thanks
Message 3 of 4
Guru
Good to hear.
Enjoy.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 676 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
