ROLgear
Jul 21, 2022Aspirant
Orbi RBR350 wired connections and internet constantly dying
Since the last 2-3 weeks my Orbi RBR350 keeps going down. Purple light off and on, Virgin Media tests showing all is fine.
Reboot of Virgin Hub 3 then Orbi solves it. But my wired satellite doesn't always work. Wrong addresses issued to devices that have fixed IP and ethernet connnections (but not wifi) not showing up as connected despite reboot of ethernet hubs.
Sometimes I can't connect to 192.168.1.1 or the Orbi app on wifi.
Driving me mad, any suggestions? I've checked cables, hubs, reset hubs and devices multiple times.
Firmware V4.4.0.10_2.10.63
Sort By
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktopTry option #2 first.
- ROLgearAspirant
Thanks, the Virgin hub has been in modem only mode since I got the Orbi so there shouldn't be a double NAT condition as it's not assigning IPs or has wifi etc. I had made no changes to anything before the problem (no settings or hardware changes) so am hoping it's a firmware issue.
I've performed a factory reset on the Orbi and crossing my fingers that it fixes things...
Any progress on this?
